1978 - 1996 Big Bronco
TP Sensor
Old Mar 15, 2004 | 10:17 AM
fishin machine's Avatar
fishin machine
TP Sensor
I had my TP Sensor go bad on me in Jan. I replaced it and it ran fine, until now. The truck is starting to do the same thing, it will idle at 1000-1200 for a while then drop back down. Some days it does and some it doesn't. Can anyone help?
Thanks
Abel
Old Mar 15, 2004 | 04:32 PM
DW2455's Avatar
DW2455
have you tried taking your IAC valve off and cleaning it real good? may help DW
Old Mar 15, 2004 | 11:19 PM
Norm Carter's Avatar
Norm Carter
Did you check to make sure the TPS is still screwed in tight? On mine it's a tough one to get to and if it's loose after replacement that could do it.
Old Mar 16, 2004 | 05:01 AM
bigric's Avatar
bigric
I'm adding another return spring to my throttle body when I get off work in a few hours because it doesn't always return fully when I let off of the gas. Start by looking at that. Otherwise, make sure that the TPS voltage is reading LESS than 1.0V at rest. I like to go a bit lower, like around 0.97, just in case it doesn't come to rest at the same position.
vtjvt
17
Jun 10, 2014 11:54 PM
taxgod4u
2009 - 2014 F150
Apr 5, 2014 09:36 PM
scbras
2004 - 2008 F150
Nov 30, 2010 10:03 AM
w_huisman
Sep 22, 2009 10:28 PM
Rebelliouswon
Paint & Bodywork
Nov 24, 2007 04:38 PM
