main seal leak
Old Mar 14, 2004 | 09:33 PM
quincyjr's Avatar
quincyjr
main seal leak
i have an 88 f150. the main seal is leaking uncontrollably. it is a straight 6. will i have to pull the engine to replace that seal?
Old Mar 15, 2004 | 07:03 AM
larry derouin's Avatar
larry derouin
Nope. Just pull the tranny, Flywheel/flexplate and you're there.
If ya got a manual tranny, now would be a god time to put in a new clutch too, especially if the Rear main went bad.
If a slushbox, just drain, change fluid and filter.
Old Mar 15, 2004 | 10:55 AM
quincyjr's Avatar
quincyjr
thank you, i just got this truck from my father and law, i was hoping it wasnt going to be much trouble
Old Mar 15, 2004 | 11:23 AM
Josh913's Avatar
Josh913
Heres a tip for ya, If is difficult getting the old seal out, Take a drill and a small drill bit and drill to small holes in the seal across from each other, then thread in two screws and use the backside of a claw hammer to pull it out. smear some grease on the drill bit to help keep shavings from getting into the engine
