Sponsored by: Real Truck
V-10 power differences-
Old Dec 23, 2000 | 10:59 PM
fishinbum's Avatar
fishinbum
Old Feb 20, 2001 | 07:04 AM
4byford's Avatar
4byford
In 1999, the 415 cid V-10 had 275 HP, 410 ft. lbs. torque. In 2000, it was factory rated at 310 HP, 425 ft. lbs of torque, in Super Duty/Excursion form. Can anyone tell me what the changes were, and if it is possible to update a 99 spec engine to reflect the higher output of the later model? Is it computer, cams, injectors, throttle body?????????????
Thanks in advance-
Old Feb 21, 2001 | 01:43 AM
V10man's Avatar
V10man
My understanding is that Ford changed the cam profiles, valve angles and intake manifold design to add the extra power. You'd be looking at replacing some expensive parts. You're prolly better off going the aftermarket route(headers, cat-back, air filter, chip)
Old Feb 21, 2001 | 08:00 AM
4byford's Avatar
4byford
Thanks- I was hoping to pick up the extra power with just a radiator cap change or something.....
