abs working on and off
Old Mar 14, 2004 | 03:06 PM
patrickgw's Avatar
patrickgw
the abs brakes have worked on and off on my truck for the past few years now, what might be causing this? ussually for a couple week at a time they won't work, and the light will come on if you brake hard and the wheels start locking up. its a 1996 b-3000, with 300,000 Kilometers
Old Mar 14, 2004 | 06:17 PM
rangersvt04's Avatar
rangersvt04
bad connection, 4 wheel abs i assume? check the rear speed sensor( on top of the diffrential) and check and see if the gear on the back of the rotor is bent if it is well its time to do a break job rotors, pads. but first check and macke shure every connection is clean and there are no bare wires.
Old Mar 14, 2004 | 08:21 PM
Ken00's Avatar
Ken00
If you have RABS, the next time the light is on pull the code. See the tech info post on how this is done.
