5 speed transmission
Old Mar 14, 2004 | 02:38 PM
anaconda's Avatar
anaconda
I am buying an 88 F-150 that needs a tranny. The junkyard said there are seven different possibilities. The door sticker says code "M". Can anyone help with what I need. Where on the tranny does it give the ratio? That is what the guy said was different. Thanks in advance.
Old Mar 14, 2004 | 03:02 PM
acerockola77's Avatar
acerockola77
Code M would be the M5OD 5 speed transmission. Personally I would bite the extra buck and go for a ZF 5 speed transmission, which is a heavier duty.
Old Mar 14, 2004 | 10:09 PM
ryanp's Avatar
ryanp
and i have just the tranny for you for sale...it's the small block ZF tranny will bolt to the 4.9 ,5.0 and 5.8. and i come down to melbourne very often being thats were i'm from.
Old Mar 16, 2004 | 07:04 PM
shotgun's Avatar
shotgun
ZF
Ryanp: I am interested in a ZF. Whats the story. Where in Florida are you? I am about 30 miles west of Dothan, AL. A small town called New Brockton.
Chris
Old Mar 16, 2004 | 10:13 PM
ryanp's Avatar
ryanp
i have a 98 cummins turbo diesel waiting to go into my truck....and i'm going with the NV4500 5 speed since it bolts right up to the cummins engine....there is nothing wrong with the ZF...perfect shape has 120k miles on it....no leaks or drips or funny sounds...my truck is a 4x4 so it has the adapter and all...although i now see that your truck is a 4x4 as well. I live in tallahassee...not very far from you at all...hell it's still in the truck you can even drive it if you like....looking to pull it out next weekend. lemme know if you are interested. thanks i have it posted in the classified section and you can email me from there...makes it easier since i'm not on here everynight....later
Old Mar 19, 2004 | 12:21 PM
anaconda's Avatar
anaconda
ryanp email if you still have the trannsmission. also would i need anything else to switch it?
