compression ratio
Old Mar 14, 2004 | 12:39 AM
bigblocksix's Avatar
bigblocksix
compression ratio
hi everyone, im rebuilding an 86 351w that i want to run on regular 87 octane gas, should i stick to stock replacement pistons or move up to flat tops? just wondering if it would ping like crazy with flat tops and regular gas
Old Mar 14, 2004 | 06:51 AM
TheWiz427's Avatar
TheWiz427
If your just rebuilding for general use i would stick with stock pistons and you should'nt have any problems.
Old Mar 14, 2004 | 11:13 AM
bigblocksix
well for this rebuild i want some more power so its gonna have home ported heads, three angle valve grind, comp 265 DEH cam. im still wondering what pistons to use, i know flat tops will give me more power but im thinking they might bump the compression up to much and make it detonate on 87 octane gas
Old Mar 14, 2004 | 07:05 PM
TheWiz427's Avatar
TheWiz427
I have flat tops in mine and late model heads(pretty much stock except heads)I run the mid grade which is 89 and don't have any problems but if i go to 87 it will ping a bit.
