460 cylinder head
Old Mar 13, 2004 | 11:50 AM
stoo's Avatar
stoo
Question 460 cylinder head
HELP! I have a 1997 F350 with a 460 FI (G) motor, the drivers side cylinder head is broken and in need of replacement. Does anyone know what heads I can use with out modification? I want to keep everything the same (manifolds, etc) Also, if anyone has a line on used heads for this, please help.
Old Mar 13, 2004 | 01:36 PM
scroob's Avatar
scroob
Uhhhhh.... wrecking yard?
Old Mar 13, 2004 | 06:39 PM
built4wheelin's Avatar
built4wheelin
the head is broken?
maybe you could have a machine shop weld it for you?
your heads should be F3TE castings. any heads from a '93 and up 460 with those same casting numbers should work for you.
