strange bolt-m5od
Old Mar 13, 2004 | 06:57 AM
shakyhiway's Avatar
shakyhiway
Question strange bolt-m5od
oh so now it sends,funny computer,i apolagize again guys.now my question was ifound a bolt on the pass side of mytrany,m5od that was really loose i mean finger tight. what is this for? it is opposite of the drain/fill plugs.can i put lock tite on it so it dont come loose again or will i need this for some thing later? good thing i was checking thinks out other wise it would of fell out down the road.thanks for the info and again sorry for the wasted space.
Old Mar 13, 2004 | 11:43 AM
steell's Avatar
steell
My guess is, it's the "Reverse Idler Shaft Fixing Bolt". Sorta near the bottom passenger side of the case? It locks the reverse idler shaft in position, so if it's loose, the idler shaft may have moved. Opening up the trans may be a good idea.
Old Mar 15, 2004 | 12:26 PM
shakyhiway's Avatar
shakyhiway
i have never heard of a reverse idler shaft fixing bolt. can you explain it a little more? it did not afect the way it drove it still goes into reverse and drives good for a m5od. i really dont want to open it up unless i really have to.the trany has only 30to40 thousand miles on it,i had a shop put it in when the last one shot craps on me. realy exspensive
Old Mar 15, 2004 | 05:11 PM
steell's Avatar
steell
My quote was straight out of the manual. Based on your description, that was my best guess.
