speedometer trans. gear
Old Mar 12, 2004 | 05:20 PM
tlb's Avatar
tlb
does anyone out there know how to calculate the proper number of teeth for speedometer gear in a c4 transmission?
Old Mar 13, 2004 | 07:03 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Re: speedometer trans. gear
Terry,
If you have a speedometer gear in there now, I can tell you how to approximate the right one. First, figure out many miles per hour and which way you are off. If the speedometer reads too high, you need a gear with more teeth. If it reads too low, you need a gear with fewer teeth. Each tooth is worth about 5 MPH, so you can go from there. It is possible to have a combination for which there is no correct speedometer gear. I know this method works because I've used it several times over the years...
BTW, you can also have your speedometer re-calibrated by most any speedometer shop if it's not quite on the money.
Old Mar 13, 2004 | 03:47 PM
tlb's Avatar
tlb
Thanks Vern.
I will follow one of my sons done the highway and see how far off i am. The cable is broke and i have the floor apart to add a new shifter. Now would be a good time to fix.
Thanks again.
