Ballast Resistor
Old Mar 12, 2004 | 12:35 PM
Smedley1's Avatar
Smedley1
Ballast Resistor
I just got my Crane Electronic Ignition Module in the mail from Summit Racing, the instructions state that I should splice into the wire from the coil to the ignition, past the ballast resistor. If the wire is the resistor, where should I splice into it?
Old Mar 12, 2004 | 02:00 PM
Franklin2's Avatar
Franklin2
If you want a guaranteed spot to have the resistor in the circuit, splice into the wire right at the positive on the ignition coil, at the ignition coil itself.
If you want a guaranteed spot to NOT have the resistor in the circuit, splice into the wire right at the ignition switch itself.
