1966 - 1977 Early Broncos
Ballast Resistor
Old Mar 12, 2004 | 12:33 PM
Smedley1's Avatar
Smedley1
Ballast Resistor
I just got my Crane Electronic Ignition Module in the mail from Summit Racing, the instructions state that I should splice into the wire from the coil to the ignition, past the ballast resistor. If the wire is the resistor, where should I splice into it?
Old Mar 12, 2004 | 03:57 PM
RCrawler's Avatar
RCrawler
If you're trying to bypass the resistor, the best way is to go directly off of the ignition switch.
Jason
