1873 351 C
Old Mar 12, 2004 | 09:58 AM
scostello58's Avatar
scostello58
Question 1873 351 C
Hi.
I just inherited a 1973 Montego with a 351 Cleveland 2v.
In my state the car is emissions exempt. How do i go about getting the most out of the engine without going for my lungs.
Can the emissions controls be removed?
I have heard you can get an aftermarket intake and a 4bbl.
Is a head swap an option? I seen some outrageously priced aftermarket heads.
Thanx for you help
Steve
Old Mar 12, 2004 | 05:11 PM
Brian S's Avatar
Brian S
'73 Emissions
There shouldn't be that many emission controls on a 351C 2V. What does it have?
http://smogsite.com/ectheory.html
http://autorepair.about.com/cs/gener.../bldef_168.htm
Old Mar 13, 2004 | 01:27 PM
scroob's Avatar
scroob
Brian is correct. I would leave the EGR alone, for example. Does it have an air pump? Kinda doubt it.
Probably the only thing your '73 would have is the dual advance vacuum system on the distributor. It is also probably routed through a device on the thermostat housing.
If it's functioning, it's not hurting anything. Given the car's age, it may have already been replaced with a single diaphragm unit.
As far as heads, the ones you already have are the best for street applications.
The 4V carb is good, as well as a better cam. The 351C has a high RPM torque curve, and can really benefit from a cam that moves the torque curve lower.
Others will chime in, I'm sure.
Old Mar 13, 2004 | 03:32 PM
coolmint94's Avatar
coolmint94
I didn't know they has a 351C in 1873, maybe it's a little too early for and might still be a little foggy in my mind...
Old Mar 13, 2004 | 04:22 PM
scostello58
Thanz for all your replies
I was told the 73 engines were de-nutted in the name of emissions.
I just want to know how do i get the most out of my car.
351c 2v fmx trans 3.00 open diff
I want to set it as a highway cruiser with ba!!s
Old Mar 15, 2004 | 12:41 PM
scroob's Avatar
scroob
"I didn't know they has a 351c in 1873, maybe it's a little too early for and might still be a little foggy in my mind..."
That would have been the 351C steam engine.
Just kidding.
