Rattling noise
Old Mar 12, 2004 | 07:48 AM
mymechanic'sanidiot's Avatar
mymechanic'sanidiot
Rattling noise
Hey folks! Got another quick ,and hopefully not too expensive as I just lost my job, question for ya. Whenever I am going up a hill with my 98 3.0 AT, there is a rattling sound. I can hear it pretty clearly in the passenger cabin. It doesn't matter what the grade is on the hill or the speed. It happens only when I have to press down on the gas pedal to maintain my speed, lest I be run over in Atlanta traffic. It has been happening for awhile but I figured I'd go ahead and see what the folks here have to say. I'm not positive, as I've not memorized or completely tracked it every time, but I believe it stops when the truck shifts gears as I'm accelerating up the hill. It does not happen on down grades or flat surfaces. I should also note that I have not noticed any drivability concerns from this.
Old Mar 12, 2004 | 08:27 AM
Delta's Avatar
Delta
It sounds like your truck is pinging. The easiest fix is running higher octane gas. You can get all the information you need here!
https://www.ford-trucks.com/forums/s...hreadid=131256
