Sponsored by: Real Truck
Wire routing for stereo SD Crew PSD
Old Mar 11, 2004 | 05:44 PM
airkewl's Avatar
airkewl
I have a 2000 SD crewcab PSD. ANyone got advice for how to route wires from one of the betteries to behind the rear seat to hook up an amp, a CD changer and a 8" Bazooka?
Thanks
Tony
Old Mar 12, 2004 | 04:13 PM
maypo's Avatar
maypo
I used to go under the step plate panels when I did cars years a go. I have not checked my truck but can only assume that there is room there for yours.......
Old Mar 12, 2004 | 04:19 PM
n578md's Avatar
n578md
If you have an automatic, you can use the passthrough plate for the clutch master cylinder on the firewall. It's just to the right of the brake booster and diamond shaped. Two bolts holds it on. You can drill that plate and pass the wire(s) through it. It comes in near the parking brake under the dash.
Old Mar 12, 2004 | 04:54 PM
Shadow Hills Super Duty's Avatar
Like n578md says, thats where I ran mine. There is a knockout there that you can pull out and drill then continue the wires past the front kick plate and under the rocker covers all the way to the back. I have pictures of my complete install if you want them.
