Sponsored by: Auxito
heater sounds
Old Mar 11, 2004 | 02:01 PM
bax's Avatar
bax
heater sounds
I have a 1998 F150. Lately I have been hearing some funny sounds coming from the dash. Usually when I start the truck up or rev the engine up or give it a lot of gas, I can hear what sounds like water rushing through pipes from behind the dash (center). It sounds like bubbling or churning water.
Old Mar 11, 2004 | 02:35 PM
dakota_viking's Avatar
dakota_viking
You may want to check your coolant level. It sounds like you have bubbles in your cooling system and the noise you hear is the bubbles going through the heater core.
To make sure you don't have a cracked heater core, turn on the defroster and see if you get steam out of the vents on top of the dash.
Good luck,
Tim
Old Mar 11, 2004 | 03:00 PM
bax's Avatar
bax
Is there a good way to remove the air, or do I just fill up the coolant to the top of the radiator. Thanks for the quick response. The site is awesome.
DTL504
Dec 24, 2011 10:08 PM
RobbyMartin
1997 - 2003 F150
Nov 27, 2009 06:46 PM
fitz888
2004 - 2008 F150
Nov 22, 2008 08:02 AM
perryau1996
19
Mar 25, 2008 07:41 AM
okst1
1978 - 1996 Big Bronco
Jun 24, 2006 12:24 PM
