400 won't start
Old Mar 24, 2004 | 11:01 PM
ford390gashog's Avatar
ford390gashog
i had the same problem with the dis i just took it out and moved it 180 and it fired right up
Old Mar 25, 2004 | 08:10 AM
gas_hogg's Avatar
gas_hogg
distributor 180 off on 400
Hey guys,
I don't think I'm 180 off but it is worth a shot as I'm stumped otherwise.
I'll see if I can change it 180 and see what that does.
Thanks for the feedback
gas_hogg
Old Mar 25, 2004 | 09:40 AM
beartracks's Avatar
beartracks
Stick a thumb in number one plug hole and turn it over till it pushes it out. Then make sure the rotor bug is pointing at the correct terminal. Also double check your firing order. Hopefully it's one of those things.
Old Mar 26, 2004 | 08:15 PM
gas_hogg's Avatar
gas_hogg
Thumbs up '77 F150 won't start -Finally did
Many thanks to all you guys who responded. I finally got the old beast started tonight. I did have the distributor 180 off-as a couple of you guys thought. All the tips helped-thanks much.
Tomorrow, I'm putting everything back together and hopefully it will keep running for a while.
gas_hogg
mcmurb
Jan 18, 2015 03:16 AM
THE HOGG
18
Jun 19, 2013 09:00 AM
THE HOGG
Jun 7, 2013 07:40 AM
vera martin
Apr 2, 2012 06:41 PM
Boss Hogg 87
Oct 3, 2011 06:16 PM
