Noisy 3.0
Old Mar 11, 2004 | 11:53 AM
uturn's Avatar
uturn
Noisy 3.0
Why does my 99 3.0 sound like a diesel? I believe it is valve clatter. It is all stock with 60k miles. It started last summer, got better over the winter, and now is getting noisy again. I am running 10-40 dino oil. Do these things need valvle adjustments?
Old Mar 11, 2004 | 12:54 PM
Delta's Avatar
Delta
They do not need valve adjustment. If the lifters are chattering, you should have the oil pressure checked.
When does it make noise, idle, high speed, acceleration, etc.?
Old Mar 11, 2004 | 03:26 PM
uturn's Avatar
uturn
It does is at any speed, any gear when it is under a load until the RPM's get quite high. I don't have a tach, so I don't know how high they get. I am definitly not lugging it. The higher the outside temps get, the more it clatters. I keep the oil changed, run 87 octane, and run injector cleaner every oil change.
Old Mar 11, 2004 | 06:46 PM
Ken00's Avatar
Ken00
Sounds like you have pinging, 3.0s are know for this. First thing to do is run 93 gas and see if it clears up.
Old Mar 12, 2004 | 08:30 AM
Ugly Since Birth's Avatar
Ugly Since Birth
I changed to premium gas to see if it changed my pinging and it stopped completely. Although premium gas is more expensive.
Old Mar 12, 2004 | 02:24 PM
Ken00's Avatar
Ken00
If it clears up with 93 start by cleaning your MAF, see the tech info post for the procedure.
Old Mar 12, 2004 | 08:43 PM
uturn's Avatar
uturn
Thanks everyone. Guess I will have to get off the wallet at the gas station.
