triton5.4
Old Mar 11, 2004 | 09:17 AM
Shastabro's Avatar
Shastabro
triton5.4
1998 triton 5.4 truck is missing on cylinder3,5,8, .I had plugs and coil packs replaced and it didnt help .Also, had computer replaced and that didnt help .You can drive it ,however when it hits overdrive speeds it runs lousy .Anybody have any ideas?Appreciate it
Old Mar 12, 2004 | 11:48 AM
khmorse's Avatar
khmorse
I just had a mis-fire in #7. I changed the plug and that was it. It also drove lousy at overdrive speeds. When I turned the OD off, the RPM's wenth up and it was OK. Unfortunately, I would have done what you did. I guess after that it's time for the shop to look at it. $$$$$$$
Old Mar 14, 2004 | 10:45 PM
LxMan1's Avatar
LxMan1
Fuel injectors failing?
Old Mar 19, 2004 | 09:34 PM
problmsolver's Avatar
problmsolver
ya, have fuel pressure ck'd going down the road and have a good load on the engine (like pulling a long hill). may have injectors plugged.
Old Mar 21, 2004 | 01:10 AM
Big Craig's Avatar
Big Craig
the 5.4 fuel injectors are easier to r & r than the spark plugs, take them all out and have them professionally cleaned for less than $100
Old Mar 23, 2004 | 11:33 PM
jeffchickering's Avatar
jeffchickering
what about those kits you buy with a can of cleaner, and the hose you hook up directly to the fuel rail? I cant find any here locally, but does anyone else use these kits? I've seen 'em on those tv shows like hot rod tv and such
Old Mar 24, 2004 | 08:24 AM
Big Craig's Avatar
Big Craig
They do work good, I have seen them at NAPA for about $70, it is best though to remove them and check that the hats( heat shields) are in good shape.
Old Mar 24, 2004 | 10:45 AM
1olddog2's Avatar
1olddog2
how do u know its 3 5 8 ??
Old Mar 27, 2004 | 10:33 PM
LxMan1's Avatar
LxMan1
OBD-II gives specific cylinder codes when missing.
gospeedracer
Feb 23, 2011 01:21 PM
Hall382
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 9, 2008 07:41 AM
girls2
1997 - 2003 F150
Jul 31, 2005 01:27 PM
ceejcr
Modular V8 (4.6L, 5.4L)
Sep 15, 2004 09:45 PM
cturboaddict
Jul 5, 2004 11:24 PM
