could someone decipher these codes?
Old Mar 10, 2004 | 07:18 PM
jwtaylor's Avatar
jwtaylor
I had a link but seem to have lost it.
The codes are:
KOEO CODE
522 - I think this one means not in neautral or out of gear, which it was, so I don't care about this code, yet
CONTINUOS CODE
32 - I think this one is egr, I am not certain but feel free to let me know.
7 - I need this one defined.
RUNNING CODE
311- I also need this one defined, I believe it means it didn't sense the power steering sensors, which is okay because I may have turned the steering wheel to soon, but let me know for certain.
What happened was the wifes truck when she lets off the gas the check engine light comes on, when she gives it gas, the light goes off. I am thinking faulty sensor (egr) or probably another broken vacuum line. I would appreciate it if someone could let me know what the above codes translate too, I recognize a couple but the "7" is new to me. thanks
Old Mar 10, 2004 | 07:23 PM
EPNCSU2006's Avatar
EPNCSU2006
I think it's a 327 and not a 32 and 7. Codes would either be 2 or 3 digit, and it looks like yours are 3. 327 is EVP or DPFE circuit below minimum voltage, 311 is Thermactor air system inoperative, and 522 is Vehicle not in PARK or NEUTRAL during KOEO, like you already figured out. http://fordfuelinjection.com/codes.html is a good list for future reference. Hope you get this figured out.
Old Mar 10, 2004 | 07:30 PM
jwtaylor's Avatar
jwtaylor
EPNCSU2006
Appreciate it, I knew you'd be all over this one, thanks.
You know it could be 327. I thought it paused after the 32 more than usual but I could be wrong, now that I think about it they are 2 or 3 digit codes. Looks like I will be testing sensors and vacuum lines. I just recently replaced the evp sensor and vacuum line, which turned out they were both faulty, codes went away, and now they are back 2 months later.......interesting.
Thanks for the link, yeah that was the one I had but for some reason, I put it somewhere and couldn't find it. later
ShadowWolf
Jun 13, 2012 05:10 PM
bluestreak1979
1983 - 2012 Ranger & B-Series
Aug 21, 2006 08:48 PM
mazda trucker
1978 - 1996 Big Bronco
Jul 31, 2005 11:59 AM
derbyit857
Oct 6, 2004 05:33 PM
KTMNealio
May 30, 2000 03:22 PM
