100/80 watt bulbs
Old Mar 10, 2004 | 01:28 PM
1990Fordf150v8's Avatar
1990Fordf150v8
Question 100/80 watt bulbs
Has anyone used or had back luck with APC's Plasma super white xenon 9004 100/80 watt blubs? also do you think they will melt the headlight housing?
Old Mar 10, 2004 | 01:39 PM
christaylor's Avatar
christaylor
I heard that for a customer that owns an Expy and tried them. stayed away after that.
Chris
Old Mar 10, 2004 | 01:47 PM
1990Fordf150v8
What are you saying you are not making any sense?????
Old Mar 10, 2004 | 09:11 PM
christaylor
Sorry I was typing fast and in a rush I'll start over.
One of my customers used them in his Expedition and they got hot enough to melt the wires and the lens housing slightly. i believe there is a conversion kit to install but I am not sure.
Good Luck
Chris
Old Mar 11, 2004 | 08:01 AM
BandBFord's Avatar
BandBFord
I wouldn't think the additional 6.6 amps (for both) being pulled by the bulbs on high would have any effect on the wiring however, I have been reluctant to use a higher wattage bulb for fear of melting my light housing.
Has anyone else used something similar? What results has anyone had?
Old Mar 11, 2004 | 09:54 AM
frederic's Avatar
frederic
Has anyone else used something similar? What results has anyone had? [/B]
Not in my f-350, no. I did put a set of 100W hi beam halogens into a pair of caprice headlamps (which I use as work lights in the garage) and after several hours of being lit, the housings got really soft and started to warp.
I attributed this to the high brightness bulbs, but also the fact that the caprice lamps weren't mounted on a car, thus getting airflow. They were mounted on a pole in the corner of the garage.
