Why the stock 94.5-97 downpipe is junk...reason 582:
After replacing my stock dp with a 3 incher I found that my stock dp had rubbed a good size groove into my uppipe and in the center is a hole the size of 2 BBs.
I wanna find another truck with a stock dp to see what exactly is so close to the uppipe but I imagine it could be the sharp flanges on either side of the dp.
So if you've still got one of these you might want to take a look at the clearance there.
I'm still tryin to figure out a fix, an exhaust clamp would be ideal but I don't think they make one with that small a diameter so maybe just a hose clamp and some sheet metal or possibly a weld.
Any better ideas out there?
I don't think the cost of another up-pipe is too high, so if it seems like a hassle trying to repair yours, you might price a new one. The hassle is in removing/reinstalling it.
Shouldn't take more than a few seconds with a welder to fix it up, unless you don't have a welder, then a JB weld/soup can patch should hold it for a while.
xlrs-
I really couldn't tell you if there is a difference in sound because I don't know how long the hole has been there.
about 6 months ago when replacing my clutch I noticed alot of soot on the passenger side of the firewall and heat shielding around the tranny and at the time I didn't realize what it was, but now after 2 weeks my new shiny dp has a streak of soot that led me right to the hole. So obviously the hole has been there a while.
I do know that when I put in my thermocouple I started the engine and reved it up to blow some of the junk out after drilling and I couldn't notice a difference in sound and that was a much larger hole.
I've got access to an arc welder but its an awful tight fit up there and I'm afraid jb weld will just run down the side, so I might just throw a clamp on there for now until I work up the motivation to put in a new pipe.
