Fuel regulator location, function
Old Mar 10, 2004 | 09:23 AM
ASH's Avatar
ASH
I've been having problems with my truck bucking under load at low RPM. Here is the link where I posted my thread: https://www.ford-trucks.com/forums/s...hreadid=212729
One suggestion to the problem was fuel regulator. My questions here are where is the regulator located on my truck (see info below), and what is the function of the regulator? Are they difficult and expensive to replace? Maybe the main question should be is whether anyone with knowledge in this area thinks the fuel regulator will solve the problem. Thanks.
Old Mar 10, 2004 | 11:42 AM
LxMan1's Avatar
LxMan1
It is located in the fuel rail near the rear of the engine. It is round and has a vacuum line going to it.
Remove the vacuum line and make sure that no fuel is present.
Use a fuel pressure gauge to check function.
Pressure should go up while idling and you remove the vacuum line.
jsalas818
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Nov 2, 2011 07:25 PM
VONxRUBENxLA
Jul 24, 2011 12:15 PM
jdberry1
1997 - 2003 F150
Aug 21, 2010 06:55 PM
Frenchy
Aug 3, 2006 07:42 PM
petem
1983 - 2012 Ranger & B-Series
Apr 4, 2003 12:39 PM
