sway bar linkage
Old Mar 10, 2004 | 12:33 AM
danquin's Avatar
danquin
sway bar linkage
can someone tell me just what Energy suspension Sway bar links are? I see people talking about putting them on their Expies... If it is something I need I wnat to know thanks
Old Mar 10, 2004 | 12:48 AM
Rickz96's Avatar
Rickz96
The reason most people put them on their truck is due to the stock linkage "dissappearing". It is cheaper to put on the EnergySuspension component than the stock pieces which will rust/break off again.
Old Mar 10, 2004 | 04:35 AM
BigMan69's Avatar
BigMan69
If you look at your front sway bar, the ends will be connected to a 5" long bolt with rubber bushings. That is the end link,,,,,the bolt and bushings. Ford end links have a nasty habbit of breaking and "disappearing". The Energy suspension kits are alot beefier and alot cheaper. You can wait till they break or just change them out now.
BigMan69
Old Mar 10, 2004 | 10:44 PM
danquin's Avatar
danquin
thanks everyone.. I checked my linkage, they are still there. but I was told that if i wanted to change them I should change the whold sway bar to a beefier one with stronger bushing (neo something) any info on this???
Old Mar 11, 2004 | 12:31 PM
Matt03Expy's Avatar
Matt03Expy
They are probably referring to polyurethane bushings. The stock end bushings and the sway bar bushings are made out of rubber. Just replacing the stock bushings with urethane ones will stiffen things up a bit.
Old Mar 11, 2004 | 11:42 PM
danquin's Avatar
danquin
thanks Matt. that is what i intend to do. thanks all!!
Old Mar 13, 2004 | 08:39 AM
myblkexpy's Avatar
myblkexpy
Contact: http://www.suspension.com/fordtruck.htm
They'll ask you to measure the bar diameter. This is for the polyurethane bushings for the frame mounts.
I think the advantage of the Energy Suspension parts is the plating. The bolt diameters are nearly the same. The Ford links are rusting and then snapping.
I'm curious, has anyone broken an E.S. link?
