Vacuum Advance
Old Mar 9, 2004 | 09:28 PM
Gary G's Avatar
Gary G
Vacuum Advance
ON my 1983 F150 300 CI does the vacuum advance on dist, take manifold or ported vacuum?
Old Mar 9, 2004 | 10:40 PM
brown 4x4's Avatar
brown 4x4
Most take ported. Do you still have the emission sticker on the radiator support? It should help you.
Old Mar 10, 2004 | 11:14 AM
PaulzF150's Avatar
PaulzF150
If you are running a single hose, use the ported vacuum. But, read below.
You should have a ported vacuum switch(PVS) on the heater hose outlet coming from the water pump(a bright greenish blue thing). The PVS allows switching from ported vacuum to manifold vacuum during prolonged periods of idle. It also has something to do with the operation of the EGR valve and emissions control. You can search this forum for "ported vacuum switch". I had a bunch of similar questions that I posted, as I have to get my truck smog tested in October. In addition to what I explained, you should be able to find some detailed information. Good luck!
