what transfer case
Old Mar 9, 2004 | 08:12 PM
TUFFY's Avatar
TUFFY
what transfer case
I have a 80 f250 4x4 c-6 auto. Can you tell me what transfer case I have, It's a light duty model I beleve . All of the door tags have been painted over so I cant get any numbers of them. I'm going to try and rebuild it. Thanks Dave
Old Mar 9, 2004 | 08:20 PM
Boss_358's Avatar
Boss_358
The easiest thing you can try is to crawl under the truck and see if you can see the tag on the tranfer case. A New Process case will have a silver round tag with more than likely, red numbering. Also check if the case is aluminum or cast iron. Looking at your year you are in kind of a grey zone. They could have been using NP205's or NP208's. I am not really sure when one stopped and the other began. I don't think they were using Borg Warner T-cases then.
Old Mar 11, 2004 | 12:16 PM
TUFFY's Avatar
TUFFY
I've got it figured out it's a np 208 thanks for your help. got just 1 more question where can i find a rebuild manual for this? or do they make one? or how hard are these to rebuild? i've done a few c-6 before. would this be much more diffucult? thanks Dave.
Old Mar 11, 2004 | 12:21 PM
Boss_358's Avatar
Boss_358
If you can rebuild a C6 you should surely be able to rebuild your NP 208. The only thing to know really is that the unit is a chain driven one, which most to all are that come in trucks. Which brings be to wonder. Doesn't the new Jeep Rubicon run an Atlas transfer case? Hmmm.
