Idle Problem
Old Mar 9, 2004 | 07:53 PM
grimmy13's Avatar
grimmy13
Question Idle Problem
Just bought a 1993 F150 (302) last month and finished rebuilding the engine this weekend. Feels like new now, but there is an idle problem when using the heating/cooling system. The engine idles smooth at about 850, but when I turn on the normal A/C, Max A/C, Defrost or Mix the engine alternates quickly between 500 - 850 rpms. It does not happen when I turn on the vent or floor blower. Tested the battery and alternator w/ a multimeter and both are working fine. I also am getting an engine code for a bad oxygen sensor, but I don't think it is related. I replaced the sensor and tested the whole EGR system and no problem. Kinda stumped right now and just need a few ideas on what to check to fix the idle problem. Thanks
Old Mar 9, 2004 | 08:00 PM
doccamel's Avatar
doccamel
IAC valve. When I did my 460 for some reason it just decided to act up. Can probably just remove and clean it and ait will be fine.
Old Mar 10, 2004 | 02:27 PM
grimmy13's Avatar
grimmy13
doccamel, thanks for the advice. That would of been one of the last things I checked, after spending my paycheck at auto zone to try and fix it. I pulled it off this afternoon and cleaned it out and works like magic (for now).
Old Mar 11, 2004 | 08:09 PM
doccamel's Avatar
doccamel
A lot of time it's the little things that make the differance. That is why this place Rocks. Other perspectives and experiances helping everyone out. Has been very educational for me.
