Wet seatbelts??!!
Old Mar 9, 2004 | 06:59 PM
robert56's Avatar
robert56
Wet seatbelts??!!
Has anyone had a problem with the seatbelts in their truck getting wet when it rains? Mine will soak the speaker and the portion of the seatbelt behind the plastic molding when I leave the truck out in the rain. It's a '94 F-150 standard cab. I thought that it might be water getting in around the third brake light housing, so I added some RTV silicone to the gasket between it and the cab, but the seatbelt is wet again tonight. Has anyone else had this problem and if so, how did you fix it? Thanks
Rob
'94 F-150
Old Mar 9, 2004 | 07:51 PM
doccamel's Avatar
doccamel
The drip rail over top of the doors may be leaking into the cab. May want to check there too.
Old Mar 9, 2004 | 10:23 PM
Scott's 88 F150's Avatar
Scott's 88 F150
I have the same problem, but only on the passenger belt. Wife made it one of my honey do's.
