difference between 302
Old Mar 9, 2004 | 06:15 PM
bry211's Avatar
bry211
has anyone ever heard of a difference between a southern 302 and a upstate one please let me know
Old Mar 9, 2004 | 08:14 PM
w951wxj's Avatar
w951wxj
The only think I can think of is the Mexican block being the "southern" block. It's a better block due to high nickle content
Old Mar 10, 2004 | 04:51 AM
RTM's Avatar
RTM
The mexican blocks did not have higher nickle in them. There was a post on this a while back. That is know as a myth. The blocks did have thicker main bearing caps and a thicker cast block making them stronger and it's my understanding there were used in buses and trucksdown there.
Old Mar 10, 2004 | 07:28 AM
w951wxj's Avatar
w951wxj
I stand corrected. I do have a pushished book that does state this as fact and goes the other way saying the myth rebuttle is really the myth. The book has some Ford authenticity to it in the way of foreward and stuff. My problem right now, is the book happens to be a "myth" somewhere in my house.
Old Mar 10, 2004 | 11:27 AM
RTM's Avatar
RTM
w951wxj, are you saying the blocks did have a higher nickle content? I am just going off of what I have read on the mustang site I surf daily.
Old Mar 10, 2004 | 12:58 PM
w951wxj's Avatar
w951wxj
I know that this past year I picked up a book about rebuilding small block fords - it stated that the Mexican blocks did in fact have higher nickle content and the stronger mains. it did state that most of the blocks ended up in trucks/buses. it sort of went out of it's way to make a point of finding a block where, if I remember right, the casing number ended up with an M signifing that it was a Mexican block.
Old Mar 10, 2004 | 02:52 PM
RTM's Avatar
RTM
Well since you have a source of information I will now speak with more knowledge on the subject.
Old Mar 10, 2004 | 02:59 PM
w951wxj's Avatar
w951wxj
Maybe, I have a source but not every book is 100% accurate also. He who wants to think there is more nickle in a Mexican block and can get his hands on it great - If I don't have one in hand, it doesn't really matter if there is more nickle in the block or not. Thanks for the comments!
Old Mar 10, 2004 | 03:13 PM
bry211's Avatar
bry211
thanks for all the replys
Old Mar 13, 2004 | 08:14 AM
bry211's Avatar
bry211
are the pistions bingger and the crank different
Old Mar 13, 2004 | 03:55 PM
pud's Avatar
pud
no all the internals are the same. And the Mexican block did have more nickel, Ive got a book that also says so. Its SA Engine designs Performance parts interchange manual. It goes into great detail, and all information in their book is from Ford.
Old Mar 14, 2004 | 08:24 AM
bry211's Avatar
bry211
where would I pick up this book
Old Mar 16, 2004 | 11:15 AM
pud's Avatar
pud
your library or parts store could order it in
