i am new to the diesel motor. my question is how long does it take for the oil pressure gauge to come up to show pressure on a cold start. mine seems to take several seconds to show any pressure is this normal. i have used the block heater and still took a while for the oil pressure to show on the gauge.
Fords gauge is a bit slow.........your profile does not show where you are from........
Is it cold does the truck sit out
What is your build date?
How many miles.
What oil
thank you..i live in ohio the temps not been that cold low 30's and the truck does sit out. i just got the truck it has about 600 miles on it and it has what ever oil the factory uses. the build date is july 03
I don't know if you have seen it or not on FTE, the oil pressure gauges on the newer Fords are "idiot light" type of gauges.
The oil pressure sending unit is a "normally open" switch that
closes with about 7PSI of oil pressure. The gauge will then read
about 1/2 scale, and will not show fluctuations in oil pressure.
Yes, the guage itself is analog. Unfortunately the sending unit is a switch. So they were not technically wrong, just didn't spill all the beans.
Lariat
PS, still say you could make these work like the older guages, with a "real" sending unit. Oh well, might just as well buy a "real" guage to go along with it!
