2000 Exp. Horn Problem
Old Mar 9, 2004 | 01:10 PM
ras0414's Avatar
ras0414
My 2000 Exp. has a horn problem. Horn used to sound normal and tough, something happened where now the horn sounds very whimpy and just high pitched like popey's pipe....you know, Im popye the sailer man .."Horn, Horn". Are there 2 horns undr the hood and maybe one broke? Where are they, how can I locate them? And if i need a new one where is the best place to get it.
Thanks for your help,
RAS
Old Mar 10, 2004 | 09:29 AM
sstclair00's Avatar
sstclair00
Exclamation same problem before...
I have an 2000 Expedition also and the horn did the same thing...until it finally just crapped out! I just replaced them for about $20 bucks for a set of two. The horns are behind the bumper and under the light on the passenger side. It was easy to do and took about 10 minutes!
good luck
Old Mar 10, 2004 | 07:25 PM
prcrboy's Avatar
prcrboy
Its probally the "low" tone horn. The two work together, one is high pitch and the other low pitch. Check for loose wires, and if hooked up, check a salvage yard..
