Knock sensor thread count
Old Mar 9, 2004 | 08:05 AM
tulsaokjoel's Avatar
tulsaokjoel
Question Knock sensor thread count
I'm going to install an '84 302 into my '87 F150. I am wondering what thread count my current knock sensor is, so I can make sure I have a hole drilled and tapped in the '84 for the sensor. There looks to be a tapped hole there already, but I'm not sure if it is the correct size.
Thanks,
Joel
Old Mar 9, 2004 | 11:56 AM
BandBFord's Avatar
BandBFord
I'm not 100% sure however, I believe the sensor is 1/4" NPT (national pipe thread).
Old Mar 9, 2004 | 12:32 PM
tulsaokjoel
Can anyone tell me if it is located in the engine block or the intake manifold?
Thanks.
Old Mar 10, 2004 | 09:33 AM
tulsaokjoel
Anyone?
Old Mar 10, 2004 | 12:16 PM
EPNCSU2006's Avatar
EPNCSU2006
I'd say the block, although I can't really see exactly where it is back there.
Old Mar 10, 2004 | 12:18 PM
tulsaokjoel
Autozone.com says it's in the intake manifold, but I've heard others say it's in the block.......... Surely someone out there has changed one that can tell me where it is. It is hard to see back in there.
Old Mar 10, 2004 | 03:10 PM
innecity4wheelin's Avatar
innecity4wheelin
my 302 had it threaded in the block, but when i did my swap, i tack welded a bolt to the back of the block. most people have left it hang with no problems. dot see why there would be any difference attaching it to the intake either. if it was in the intake that would be going with the swap...lol.. on the newer blocks there was a flat machined place to put it, older blocks was harder and i just tacked a bolt to the side of the web on the back when it was on the stand
Old Mar 10, 2004 | 03:20 PM
tulsaokjoel
Thanks for the info. I thought the sensor had male threads though, which would mean I'd need a nut to tack to the block instead of a bolt? What size bolt or nut do I need?
Jmanb13
Sep 30, 2016 09:25 PM
rock2610d
Modular V10 (6.8l)
30
Jul 8, 2016 07:54 PM
warren561
Aug 12, 2015 05:21 PM
jackofalltrades
Bronco II
Jul 3, 2010 08:57 AM
jesse460
Oct 12, 2003 02:18 PM
