Needles Pegging & Radio out!
Hi everyone, My 99 Expedition EB has a stock premium sound system with CD changer in the console.
Everytime I start it up, the needles Peg for a second, then fall back to normal and work fine.
My radio turns on and off whenever it wants. I have taken it out and tried a different one and still have the same problem.
Fuses are fine.
There is constant and switched power being sent to the radio harness.
While driving, it will turn on for a second, then off. Sometimes it stays on for hours/days.
I have poked, prodded, jiggled, twisted everything in hopes to find a short......
The needles have something to do with this??
BTW,it's not raining here!
Mark
Fuses are fine.
Mark
I am not sure about the radio but when my battery started getting weak my instruments did the same thing until I replaced the battery. I think I read that if the battery is weak the computer will reset each time you start it and when the computer resets the guages all peg out for a second and then go back to normal. Hope this helps
As 18fan noted, these sort of problems are almost universally accepted to be signs of an impending battery death. I would guess, although to the best of my knowledge it's never been confirmed, that voltage variation caused by the failure of the battery to properly act as a 'juice well' for the electronic system is the cause of the intermittent problems and gauge malfunctions.
