got an oil leak.Ther is oil all over the top end of my engine.Not sure where it's coming from.88 for econolin e-250 351 w.fuel injected.It did leak from rear of intake .I have taking it apart and resealed twice leaking there again 2.But it's leaking somwhere else got oil all over my wires coil everywhere.any help appreciated
Welcome to FTE!
Only thing I can suggest is clean it up real good, then check for leaks. And maybe your PCV valve and hose should be checked. If they are clogged, you might get pressure in the crankcase forcing these leaks. Does it have a breather filter? Look at that and see if it's oily.
Is it possible that your valve covers have a broken seal? I have seen when people seal an intake they throw away the seal and use a squeeze tube sealant for the front and back, but if you have sealed it twice already, that's probably not it. I think c96drumm was right, clean it up real well, maybe try a good degreaser, and then see where the oil appears first. hope we can be of help here.
