Does anyone else have a squeaky bed?
Old Mar 8, 2004 | 10:08 PM
JD in TN's Avatar
JD in TN
... truck bed, that is.
My F250 was in a collision with a Toyota. He hit my right front fender and bumper. I had to replace them both. Toyota didn't fare as well. But my problem is: now there's a squeak, sometimes popping noise that I just can't figure out what it is. It sounds like it's between the bed and the cab, but they are not touching. Sometimes it kind of sounds like it's under the truck; sometimes it sounds like it's inside the cab. I rode in the back of the truck and I didn't hear it as well as I did when I was inside.
Can't figure this one out.
Have any of you had this problem?
Any ideas?
Thanks,
JD
Old Mar 9, 2004 | 07:51 AM
cangim's Avatar
cangim
Squeak all the time or just on speed bumps and such. Mine the little plastic spacer that is supposed to seperate the two leafs up front are just about to fall out, so it talks to me when I go over speed bumps.
Old Mar 9, 2004 | 07:55 AM
GlennJenne's Avatar
GlennJenne
Wink
Mine only tends to squeak a little when a small truck is under the rear tires.
Old Mar 9, 2004 | 08:09 AM
cangim's Avatar
cangim
does it sound like h ha ha he he e e m m i i i ?
Old Mar 9, 2004 | 11:06 AM
TJC1989's Avatar
TJC1989
Good one, GlennJynne. Rainy depressing day here in Seattle. I needed that...
Old Mar 9, 2004 | 11:55 AM
2003 7.3TD 4x4 F350C's Avatar
Has the bed been taken off to paint the truck
If so they may not have reattached the fuel tube back to the bed. There is a hose clamp the holds the filler tube to a tab from the bed. I had a noise and not all the time.
My truck was compleatly repainted and the boby shop did not reattech filler tube to bed and sounded like the bed was loose and ratteling at times.
Hope this helped. LOL
Rich
Old Mar 9, 2004 | 05:35 PM
jamesbfishin's Avatar
jamesbfishin
My bed could never sqeak enough, oh the truck bed, sorry. In all seriousness, you could try using some lube on your body mounts.
Wayne Waldrep
Dec 10, 2012 09:41 PM
okedokeno
28
Oct 26, 2012 10:45 PM
59flatbedford
Mar 6, 2011 08:19 PM
BlueOvalRage
21
May 15, 2010 04:23 PM
JD717
General Automotive Discussion
17
Jun 7, 2006 09:06 PM
