2000 psd supply pump fuel problem
Old Mar 8, 2004 | 09:08 PM
bigblock427's Avatar
bigblock427
how do you check the electric supply pump in driverside frame? truck died on highway removed fuel filter it was half filled. tried cranking with filter out and fuel level didnt rise. tach shows when cranking it tries to start but sound like its only firing on a couple cyls then stalls
Old Mar 8, 2004 | 10:18 PM
BCS_tx_dieselman's Avatar
BCS_tx_dieselman
Had same problem last year. I unplug fuel pump connection & hooked up 12 v.straight to pump,also a ground wire. Pump didn't run it just thumped. Repaced pump, turned on ignition switch with engine off new pump ran for 15 sec. then cycled off.Started engine, problem solved.
Old Mar 9, 2004 | 04:42 PM
bigblock427
yup that was it just a thump 232.00 later she runnin fine
Old Mar 10, 2004 | 08:18 AM
BCS_tx_dieselman
Where did you get the pump? Had to get mine from dealer $300+.
