header installiation question
Old Mar 8, 2004 | 03:44 PM
thecowboy's Avatar
thecowboy
Hey there
just wondering what i have to do to the exhaust to make a header bolt up on a 300 I6. or will it bolt right on factory exhaut pipe.
THANKS for the help
Old Mar 8, 2004 | 07:04 PM
thecowboy's Avatar
thecowboy
bump
Old Mar 8, 2004 | 08:39 PM
bremen242's Avatar
bremen242
Depends.
If you go with EFI manifolds from an 87+, you just need a walker downpipe.
If you have duals, you'll have to get a whole new exhaust. the singles wont fit without mods either.
Old Mar 9, 2004 | 07:37 PM
thecowboy's Avatar
thecowboy
sorry man not sure i got that. Im talking about a header not manifolds.
what do you mean by EFI. is there a diffrence in the 87 because i have an 80. and i thought the down pipe was part of the stock exhaust.
THANKS FOR PUTTING UP WITH ME
Old Mar 9, 2004 | 07:57 PM
bremen242's Avatar
bremen242
If you have an 86 or older, you can use the 87+ manifolds like headers. They give you better flow, and are fairly easy to bolt up.
However, with regular headers, you'll have to fab up a y-pipe or have duals bent the whole way back.
Old Mar 10, 2004 | 05:44 AM
thecowboy's Avatar
thecowboy
thanks alot man for clearing that up for me. so what whould you use the 87+ manifold or go with a header. the manifold sure dose sound easyer. THANKS ALOT
Old Mar 10, 2004 | 08:50 PM
bremen242's Avatar
bremen242
Header will give a little more power, but if you can get the manifolds in the junkyard, it'd be a lot cheaper.
