1978 - 1996 Big Bronco
ABS solution ... Maybe ...
Old Mar 8, 2004 | 08:17 AM
Will_01_GT's Avatar
Will_01_GT
I was hosing out my engine compartment this weekend and I think I may have solved my ABS light coming on for no reason, it was happening in either snow or rain while driving, but never when its dry out. There seems to be a ABS connection attached to the driver side fender panel, the funny thing is there are 2 holes right next to this connection leading to the wheel well, After the engine was nice and wet and then I started up, ABS light was lite bright yellow, so I was thinking maybe just enough water get up thru those 2 hole to soak this connection an cause the ABS lite to go on. I've black taped connection so hopefully I've solved this problem as we had a nasty wet snow fall this am and no ABS light, Now that I think of it maybe I should have just taped the holes I'll do that this evening
