Power window "thunk"
Old Mar 8, 2004 | 07:39 AM
mrmootsie's Avatar
mrmootsie
Hi,
Occasionally, when I "roll" my windows up in my 99 EB, there is an audible thunk or pop as they seat. Both driver side and passenger side fronts do this occasionally. Hasn't happened yet on the rears.
anyone else have this problem? Does it portend bad things?
thanks,
MrM
Old Mar 8, 2004 | 10:11 AM
Darth Baiter's Avatar
Darth Baiter
My 99 does the same thing and has for years. Mostly in warmer weather when a vent or another window is open. If you figure it out, let me know.
Old Mar 8, 2004 | 12:06 PM
Sturge's Avatar
Sturge
I had similar sounds on my '98 drivers side window. Complained about it when I first bought the truck (30K miles) but dealer never messed with it cause it worked fine. Traded truck at 118K miles and never had any problems - just a little noisy.
Old Mar 8, 2004 | 03:15 PM
okcexpo's Avatar
okcexpo
I have a '98 Expo and I have the same problem. It doesn't do it all the time but it still does it. I've never had any other issues with the window so I've never had it checked out. Let us know if you find anything out.
Old Mar 8, 2004 | 03:46 PM
Phil056's Avatar
Phil056
Likewise with my '98. I get that thunk on my driver's side mostly. I notice it happens when it's really cold out and the rubber doesn't move to well when the window pane wants to resit itself. Usually when it get warmer out the problem basically goes away. Try to wiggle (spread them apart with your fingers)the rubber gaskets where the pane sits in, this works for me most of the time.
Old Mar 8, 2004 | 04:59 PM
mrmootsie's Avatar
mrmootsie
good, glad to see I'm not alone.
Old Mar 8, 2004 | 09:13 PM
prcrboy's Avatar
prcrboy
The "thunk" is most of the time caused by the upper molding that the window seats into. Take your hand and lighty "open" the molding. That is to say, make the part that the window seats into, a little wider. Mine used to do it and this fixed it right away.
Old Mar 10, 2004 | 12:10 AM
bcareaga's Avatar
bcareaga
my 97 does it too! Glad to not be alone and to hear it's not major!
Old Mar 11, 2004 | 03:02 AM
billybubba's Avatar
billybubba
My wife's EXPY (bought it used) did it from day one. Driver's door only. Had it in the shop 2 previous times(for other issues) and both times NTF. Finally on the third trip, I explained how frustrated I was, the fixed it. I need to get a copy of the slip for the exact fix. I remember something about adjusting the glides or stops or both. But, it has been about 4 months or so and it did it once the other day.
