Bronco II Ford Bronco II
transmissions
Old Mar 8, 2004 | 05:04 AM
rowdyranger's Avatar
rowdyranger
transmissions
how can you tell the differece between mits and mazda tran ?is there any visual differences? ihave a 87 with blowed motor and a 86 with a bad trans will these swap? the 87 is 100 miles away right now but is easy to get
Old Mar 8, 2004 | 10:53 PM
geowolf's Avatar
geowolf
mits usually for 4X4 and maz for 4X2 and there is an easy way to tell..... the trans drain plug on maz drains out to the side and mits drains straight down. hope this helps
Old Mar 9, 2004 | 05:35 AM
rowdyranger
thanks for the help . do you know ifthe mits has a removable bell housing?
Old Mar 9, 2004 | 05:54 AM
Zayazz's Avatar
Zayazz
Mazda has...
...no neutral switch on the top and use ATF, Mits - 80W...
