Engine Smoke/Squeal & now Triumph !
if you have ctalytic converters you need the air pump. its purpose is to pump air into the exhaust .
what your cats do is burn off the unburned fuel that is left in the ehaust gas.the air pump feeds air for the combustion to take place. without the air pump the cats have a hard time burning off the unburned fuel so they heat up and there life is drastically reduced.also emissions are not reduced to a satisfactory level.
Well, got crapped on again with this. Got the new air pump. Everything is fine. Go to start up, it is a little rough but thought it was just timing its self. Well, water started leaking out of the exhaust pipe and the engine was making noise like it was gurgling water. Turned off engine and checked the radiator and it was not full any more. What in the hell is going on!!
Thanks for all your help.
Ben
Ben
Again, you need to check for coolant in the oil. It could be that you lost coolant because air was bleeding out of the system, or because a head gasket is blown.
It's possible that there's some coolant pooled in the exhaust work from the teardown (it happens) that's just steaming off, that the gaskets are burning in (exhaust gaskets smoke when they do that), or that you have a leak.
Check the oil, check the compression, check to see if the exhaust smells sweet like coolant. My wife and I are real pros at that now since the cracked head deal.
I don't know if this applies to Ford bolts or not, but I once did a re-build on a Chevy and had head gasket crap out on me. Turns out that you can't reuse those particular head bolts. You have to use new ones each time. (something to do with the bolts stretching with expansion / contraction)
#29
#30
Hey Guys,
I am new to this site, but have been working on cars and trucks for years. I know of only a hand full of problems that cause extreme white smoke and water consumption: 1. Blown head gasket, 2. cracked block or head, or 3. don't forget the ever so popular intake manifold gasket. Some of today's antifreeze products can rot you gaskets causing this problem. Try removing the spark plugs and cranking the engine. The spark plug hole shooting out plums of water is the one that's a problem. If it is on the rear of the engine, near the water ports, it may be your intake manifold gasket, which are far less of a pain to replace than a head gasket.
John24255
John24255
