Water pump is shot
Old Mar 7, 2004 | 08:23 PM
dbalke's Avatar
dbalke
Water pump is shot
How hard is it to replace the water pump on a 90 Ranger w/ac? Anything I need to know before jumping into it?
Old Mar 7, 2004 | 08:34 PM
Ken00's Avatar
Ken00
I never did the one on my 1989 2.9L, but I don't think you'll have any problem as long as you follow the directions in a manual.
Old Mar 7, 2004 | 09:06 PM
dbalke's Avatar
dbalke
I have a copy of the Haynes manual. It doesn't look too bad, but would like to here from folks that have replaced theirs. Should I plan on a couple hours or will it take the good part of a day?
Also, I'm going to replace the belts while I'm at it. Is there anything else that you would suggest doing while I'm at it?
Old Mar 8, 2004 | 12:54 AM
87 XLT's Avatar
87 XLT
The only thing that can be a pain is removing the fan clutch. Autozone will loan you the wrenches for this. It probably turns clockwise.
Old Mar 8, 2004 | 10:01 AM
dbalke's Avatar
dbalke
Thanks. I will probably jump intothis project next weekend, weather permitting.
Old Mar 8, 2004 | 06:52 PM
Fazda's Avatar
Fazda
i recently replaced my water pump a few days ago. it wasnt to hard and only took about 3-4 hours. my only problem was getting the fan clutch off. the fan shroud should tell u what direction the thread is on the clutch. in my 94 mazda b4000 it was a right handed thread. to get the clutch off i had to get a torch and heat up the nut, then twist it off with a wrench. the water pump had 12 bolts (11mm) and to get access to all of them i had to remove the alternator (3 bolts) and the bracket (3 bolts) that it was mounted on. that bracket also holds the tensioner pulley. good luck...
