Wide Open
Old Mar 7, 2004 | 04:17 PM
phish19's Avatar
phish19
Wide Open
when i put the throttle to floor and let off the cable to the carb get stuck still wide open. what can be done. to bet it all im at work so ill have to do it in the parking lot to get me home.
Old Mar 7, 2004 | 04:52 PM
Dealford's Avatar
Dealford
Check all the levers etc. to see if you can pinpoint the one that's sticking. All those moving parts must have wear to them and may require "re-aligning" (bending).
The problem is not with the cable itself binding in its' sheathing, right?
WD40 may help you as well.
Old Mar 7, 2004 | 05:15 PM
phish19's Avatar
phish19
thanks i went out while on break and found that the choke valve pin broke and the valve dropped down and was holding the throttle open
