Sponsored by: Real Truck
Add-a-Leafs vs. Blocks
Old Mar 7, 2004 | 09:03 AM
BigDawg54's Avatar
BigDawg54
Question Add-a-Leafs vs. Blocks
If you own an F250 or another model, why would you use blocks (2", 4") instead of adding springs to the rear of your truck for the extra payload? i know price cant be a major issue, just seems that a spring would be more usefull. thinking about adding a spring instead of the 4" F350 block.
ps. what are good Add-a-Leafs? Super Lift, Rancho, etc?
-bigdawg
Old Mar 7, 2004 | 09:14 AM
Yeti's Avatar
Yeti
Because adding springs will make the ride stiffen up, some want to retain the stock ride.
Old Mar 7, 2004 | 09:45 AM
brianas's Avatar
brianas
I had 2 leafs added to the rear spring packs on each side(F250)
If your looking to carry alot of weight -this is the best route
I carry 5000lbs in the bed and it doesnt hit the helpers
Total price for parts+labor $375.- no problems to report
