Sponsored by: Kumho
Major leak
Old Mar 6, 2004 | 06:31 PM
volfan16's Avatar
volfan16
Question Major leak
On my 74 F-100 I have a major power steering leak somewhere. It's not coming from any lines or connections. Does anyone know where this might be coming from? If so, how do i fix this problem? Thanks for any info!
Old Mar 6, 2004 | 09:50 PM
X-1's Avatar
X-1
Check at the front seal. Ford gearboxes back at leaking at the shaft seal. Fill it up, and with the motor running have a friend crank it all the way over in each direction, if leak is real bad it should be ablr to find. Spray some degreaser on there first.
Old Mar 7, 2004 | 02:40 AM
volfan16's Avatar
volfan16
Thanx X-1. I'll try that and see what happens.
