intake air temperature sensor
Old Mar 6, 2004 | 05:25 PM
87 xlt lariat's Avatar
87 xlt lariat
i have a '87 f-150. probably a stupid question but can anyone tell me were the intake air temperature sensor is. can't seem to locate.
Old Mar 6, 2004 | 07:22 PM
brrossi's Avatar
brrossi
What engine do you have?
Old Mar 6, 2004 | 07:47 PM
87 xlt lariat
forgot to mention it's a 5.0L efi
Old Mar 6, 2004 | 08:26 PM
Chris_ce's Avatar
Chris_ce
should be right around the air filter sticking in the side of the filter box
Old Mar 6, 2004 | 09:42 PM
brrossi's Avatar
brrossi
Then it is screwed into the (drivers side) lower intake just behind the distributer between the front two injecters. You need to unplug it and then find a socket to fit it. I don't recall what size. It is a fairly easy to change. Just don't overtighten the new part as the intake is aluminum. Also the replacement part I got was plastic -vs- metal. Good luck.
Old Mar 8, 2004 | 06:52 AM
EPNCSU2006's Avatar
EPNCSU2006
You'll need a 1" deep socket to get it out. brrossi has it in the right place.
nycstev
Mar 2, 2013 05:02 PM
Trevor1
Aug 24, 2008 10:07 AM
goofy69
New Member Introductions
Aug 7, 2006 04:16 PM
mike L
69
Nov 10, 2004 11:14 PM
ltabora
4 Cylinder Engines
Aug 23, 2004 05:58 PM
