1978 - 1996 Big Bronco
Transmission or Transfer Case?
Old Mar 6, 2004 | 12:42 PM
mpmusicman2004's Avatar
mpmusicman2004
I have an '87 Full-Size Bronco, 4WD, with automatic transmission. Why will it go into gear in low-range 4WD, but not 4WD and 2WD. Just grinds. For a month or so, in 2WD, I had to keep a load on it (foot on gas and brake), or it would go out of gear and start grinding. Yes, I know I need to take it to the shop, but it's the weekend and I'm broke! HELP!!!
Old Mar 6, 2004 | 03:20 PM
WhëëlMå1's Avatar
WhëëlMå1
It sounds like a transfer case problem. Have you checked all of youre linkages yet? You would be suprised at what kind of chaos a loose/misaligned linkage assembly can do.
Rich
Old Mar 6, 2004 | 04:14 PM
mpmusicman2004
As far as I can tell, transfer case linkage is okay. I inspected it from inside the truck. Pulled back carpet and removed plate. I disassembled linkage, inspected, and reassembled. Everything's pretty tight. THANKS for your reply!
Old Mar 7, 2004 | 08:38 AM
BOJOFASO's Avatar
BOJOFASO
have you installed a body lift or any other type of things. it sounds as if mayby your shift linkage has stretched or is misadjusted, or maybe a plastic grommet has deteriated enough to give you your shifting problems.
Old Mar 7, 2004 | 08:51 AM
Steve_Uzi's Avatar
Steve_Uzi
Sorry to be the bearer of bad news but... the Xfer Case is toast.... there are two Forks inside the case. I had the same problem happen to my case.. the Range fork that holds the truck in Hi-range was toast! I had the entire case rebuilt with new 2 new forks, bearings, new chain, seals etc ---> $950 installed.. I was guessing only $700... If I known it was going to be $950 I just would have spent another $800 and gotten an Atlas II.
