bronco ll transmissions swaps
Old Mar 6, 2004 | 09:20 AM
rowdyranger's Avatar
rowdyranger
will a transout of an 87 bronco ll bolt into an 86 both have manual trans and 2.9 fi engine. how can you tell if they are different? can't find any code tags or #'s on either one.
Old Mar 6, 2004 | 09:25 PM
Dealford's Avatar
Dealford
Welcome to FTE rowdyranger.
The sure fire way to see if they will interchange is to get under and look. It's not likely that somebody swapped something different into one of them.
Old Mar 7, 2004 | 05:43 AM
rowdyranger
Edited by the moderator
Old Mar 7, 2004 | 02:15 PM
Ken00's Avatar
Ken00
There are two trannies for the 2.9, a Mazda and Mitsubishi, you need to look at the bottom to determine what you have. I beleive they can be swapped but I'm not 100% sure. If you do a search here and the BII forum you should find more on this.
