Oil & Lubrication
cracked joints
Old Mar 5, 2004 | 06:03 PM
ryanben's Avatar
ryanben
cracked joints
I just performed my usual oil change and when I was lubing the joints I noticed some grease coming out of one of the joints on the right swing arm. Upon closer inspection I saw that there was a small crack in the rubber. Is this somethink I need replaced or is it ok that some of the grease came out?
Thanks for any info
Old Mar 5, 2004 | 09:48 PM
TallPaul's Avatar
TallPaul
Sorry I don't have an answer, but you may want to go a few forums up the list and post this also in the Brakes,Steering, Suspension,Tires, Wheels forum.
Old Mar 5, 2004 | 09:51 PM
peppy's Avatar
peppy
You should replace it, but its no emergency. I have grease fittings that leak bad, been there long time. Just needs greased more often. You loose grease, and gain dirt.
Old Mar 9, 2004 | 10:44 AM
MrBSS's Avatar
MrBSS
I think it depends if it's really a crack or more of a "weep hole". In my experience, many of the rubber seals have an exit spot for excess grease. I usually grease until just a little comes out.
