1978 - 1996 Big Bronco
Insufficient egr flow detected
Old Mar 5, 2004 | 12:35 PM
sdrowand's Avatar
sdrowand
I have a 1996 E.B. 5.0L .Check engine light has been on for a while , I finally got codes read. Insufficient egr flow detected came up, the guy at advanced auto assured me it was the egr valve, $60 dollars later installed new egr valve and reset computer, 30 miles later light is back on with same code. How could i diagnose the problem? thanks.
Old Mar 5, 2004 | 12:46 PM
seans64''s Avatar
seans64'
maybe go back to the guy that diagnosed it. im dealing with the egr crap right now. not much help i can bring but id take it back.
Sean
Old Mar 5, 2004 | 05:13 PM
bigric's Avatar
bigric
You've got that DPFE setup. Did you happen to change the sensor, or just the valve? Could be a faulty sensor.
The test procedure is far too long to post here. If you would enable email in your profile, I could send it to you.
Old Mar 5, 2004 | 06:54 PM
sdrowand's Avatar
sdrowand
E-Mail is enabled
Old Mar 5, 2004 | 07:31 PM
brown 4x4's Avatar
brown 4x4
Check for vacuum leaks first. Those plastic hoses crack easily and it can cause "insufficient flow" if vacuum can't get to the EGR valve.
Does '96 still use a sensor on top of the valve? If so that could be your problem. It can be tested with a voltmeter and vacuum pump.
If those check out fine, it's probably the EGR vaccum regulator (EVR). It's on top of the engine near the coil. It's a fairly cheap part from Ford (no parts store I asked could get one).
Old Mar 5, 2004 | 09:11 PM
mjl351w's Avatar
mjl351w
I am not sure about the 90's models but the 80's had a tube the ran from the back side of each hea and if it became clogged it would send the EGR as being bad .......by the time i figured it out , mine all ready had a 4BBL and headers
Old Mar 5, 2004 | 10:52 PM
bigric's Avatar
bigric
'96 uses a DPFE setup. There's a sensor box mounted on the box and it measures pressure from several places. It's more complicated than what you find on the '86-95 setups.
I've emailed the test procedure; check your email. If anybody else is interested, enable your email and let me know.
