Power Window Problem
Old Mar 5, 2004 | 08:56 AM
Smitty1019's Avatar
Smitty1019
Intermittently, my driver's side power window in my truck decides to not roll down all the way. When I push the button, it starts to roll down but stops about after rolling down only 1 cm or so. I then push button to roll up the window and the press it to lower the window and it gets "stuck" again. I repeat this process 4 or 5 more time and then it finally rolls down all the way. Anybody else have this problem or have a fix for it? Spent too much at the stealership recently...
Smitty
Old Mar 5, 2004 | 09:40 AM
buzzard's Avatar
buzzard
Probably the switch or the motor. I'd bet it's the motor. If you're fairly mechanical, they aren't very expensive at ~$50 each, you should be able to replace yourself.
